Hour meter
Old 04-23-2021 | 12:10 PM
TYPHOON's Avatar
Default Hour meter
Does the hour meter on the motor keep reading hours if the ignition is on but the motor is not running?
TYPHOON is offline
Old 04-23-2021 | 12:14 PM
It shouldn't that would totally defeat the purpose of the "engine hour meter"
302 is offline
Old 04-23-2021 | 12:27 PM
I thought any time key was in run position hour meter ran whether engine was running or not.
liberator221 is offline
Old 04-23-2021 | 12:28 PM
Dave M's Avatar
Veteran: Navy
It depends, the old style 80's, 90's would run when you turned the key.
Dave M is offline
Old 04-23-2021 | 12:49 PM
Sydwayz's Avatar
Forum Regulator
It depends, but yes, that it typically the case.
Sydwayz is offline
Old 04-23-2021 | 01:28 PM
Why the question?
Old 04-23-2021 | 02:00 PM
TYPHOON's Avatar
I was hooking up a stereo on a single battery boat and thought it needed to be wired into ignition instead of direct to battery where I know someone will forget to turn it off.
TYPHOON is offline
Old 04-23-2021 | 02:10 PM
SB
You would need a 4 way ignition switch for that. Accessory / Off / Run / Start
Psst: 99% of boaters would kill a battery that way too. Doh !
SB is offline
Old 04-23-2021 | 02:25 PM
OldSchool's Avatar
Yes...The hour meter will run, but the hours on the computer only go up if the engine is running. Don't ask me how I know... LOL
OldSchool is offline
Old 04-23-2021 | 02:47 PM
Put the REM/ignition wire on a rocker switch.
Put a battery kill switch in the boat, shut it off when you call it a day.
apex svt is offline
