260 Prowler Water System
Recently bought a 260 prowler and looking to figure out how the water system operates. Flipping the switch in the cuddy seems to not do anything except light up. I believe the pump is on the port side in the front of the engine compartment? is there a float in the tank that the pump wont run unless it senses water level? not looking to fill the tank with water with no way to get it out...
I owned one about 20 years ago. IIRC, there is a drain on the tank. There is no float in the tank. You could have a blown fuse or bad pump if you don't have the pump turning on. I do believe the pump will turn off when it builds pressure though. Open a faucet, and turn the pump on, so see if it has built pressure.
