Fuel pickup tube >
Fuel pickup tube
Fuel pickup tube
Old 05-02-2021 | 09:41 PM
Default Fuel pickup tube
I have exceeded the output of my fuel system. I have been searching old post and I know this has been figured out. Cannot find the information on how to modify the pick up tubes. Have 3/8" NPT female on the tank and need to maximize the fuel volume. Going to step up from -6 an to -8 an on the intake side of the fuel pump and upgrade the fuel pump.
jeffswav is offline
Old 05-02-2021 | 09:49 PM
Does the fitting on the tank come off?? When I went up on size I was able to simply replace the fitting.
phragle is offline
Old 05-02-2021 | 11:14 PM
Unfortunately no, 3/8" thread on tank. Worked fine for 500 HP, not for 600+.
jeffswav is offline
Old 05-03-2021 | 06:03 AM
then if you cant do that, you are going to have to have a new pickup tube made and installed.
phragle is offline
Old 05-03-2021 | 08:00 AM
Correction, I will have to make a new pickup tube and install it. LOL Pre-made off the shelf tubes that I have seen will not do what I need.
jeffswav is offline
Old 05-03-2021 | 08:23 AM
F-2 Speedy's Avatar
dont think you'll have an issue running -8 on a 3/8 pickup, hell Im running -10 on the whipples on stock pickups and way more that 600 ponies
F-2 Speedy is offline
Old 05-03-2021 | 01:26 PM
Interesting, so maybe the pickup is not as big of a problem.
jeffswav is offline
Old 05-03-2021 | 02:02 PM
SB
At That level, it depends on other things in the system too. :wink
SB is offline
Old 05-03-2021 | 08:25 PM
It seems to be more complicated above 500HP.
jeffswav is offline
Old 05-03-2021 | 09:42 PM
Well if you dont want to weld on the tank, make a new pickup tube with a flange at the top that mounts like a the fuel level sender, then cut a hole and screw it down with a gasket.
phragle is offline
