Fuel Pump
Old 05-03-2021 | 08:29 PM
Default Fuel Pump
What fuel pump are you guys using for MPI 43PSI, 60lb injectors, about 650 HP. Found a lot of options out there but not many marine USCG rated. Don't want to overkill it with a high current model.
jeffswav is offline
Old 05-03-2021 | 09:50 PM
Rookie's Avatar
https://www.cpperformance.com/p-1008...fuel-pump.aspx
https://www.aemelectronics.com/produ...flow-fuel-pump
Rookie is offline
Old 05-03-2021 | 10:03 PM
Are you using this one? I was actually debating on this same model.
jeffswav is offline
Old 05-03-2021 | 10:34 PM
Rookie's Avatar
Yes, I bought 2 for my Holley EFI project. I just dyno'd the other weekend. At full load 584 HP maybe 1PSI variance.
Rookie is offline
Old 05-04-2021 | 07:54 AM
I have always used Weldon 1100-A. Not sure if they are USCG approved, but they sure work well.
snapmorgan is offline
Old 05-04-2021 | 08:13 AM
F-2 Speedy's Avatar
I run Aeromotive A-1000 marine pump
F-2 Speedy is offline
Old 05-04-2021 | 08:26 AM
What's the lift on this pump? I wouldn't want to mount it to low in the bilge.
ThisIsLivin is offline
Old 05-04-2021 | 09:09 AM
Pretty sure I am going with this pump. Going to run -10 AN in and -8 AN out to the filter. What did you use for mounting?
jeffswav is offline
Old 05-04-2021 | 09:16 AM
Rookie's Avatar
I don't know the lift. But friend just mounted 2 to near top on outboard stringers and it worked just fine.
I use the 60mm for pump and 50mm for filter.
https://www.ebay.com/itm/15407628807...Cclp%3A2334524
Rookie is offline
Old 05-04-2021 | 04:20 PM
Rookie's Avatar
Rookie is offline
