Do I need to look at a 5 blade? >
Old 05-17-2021 | 09:22 AM
Default Do I need to look at a 5 blade?
I have a Velocity 280 with a single BBC with about 700hp. I have tried a Hydromotive QIV 27pitch and a labbed Bravo 4 blade 30 pitch. I have a modified B1 with a nose cone, 1.5 ratio and my prop shaft is 4" below my pad. The Hydro breaks out on the slightest throttle getting on plane and will break loose in rough water really bad. The labbed Bravo gets on plane pretty well and will stay connected as long as I don't hit the throttle to hard. I have to watch both props when I get to 3000rpm as the motor is getting into it's powerband and will break both props loose pretty easy. I'm still working out the top end, but the bravo will run 80 at 5000rpm all day with a full tank and 5 guys on board. When I'm by myself and horsing around I can pretty much break the bravo loose on demand from 30-40mph. It's like driving my supercharged Corvette when the tires are cold. Any suggestions? What do you guys do that are running serious power
ThisIsLivin is offline
Old 05-17-2021 | 01:29 PM
I'd definitely try a 5 blade. The other option to try is a 1/2" or 1" drive spacer
Griff is offline
Old 05-17-2021 | 01:48 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Just be aware that the 5 blade "bites" the water harder on re-entry. You have to be better on/off the throttle when the prop is coming out of the water so as that HP/tq you are pumping through that B1 does not tear it apart.
Sydwayz is offline
Old 05-17-2021 | 01:53 PM
You are 4" below the pad?
Wildman_grafix is offline
Old 05-18-2021 | 07:23 AM
Yes, prop centerline is 4" below the stepped pad.
Old 05-18-2021 | 10:10 AM
I'm getting ready to test a Max 5 on my Donzi today. Pretty sure the pitch is too small though.
thirdchildhood is offline
Old 05-18-2021 | 12:07 PM
What pitch/diameter?
I might be interested in it, for my Donzi😁
Alexanderlindahl is offline
