Norcold refrigerator removal >
Old 05-18-2021 | 05:42 PM
Veteran: Army
Default Norcold refrigerator removal
I removed 3 screws on each side of the fridge, it still will not move at all. I don't see any other screws anywhere. Anybody have any info on getting this out? The boat is a 30 PowerQuest, thanks..
snopro13 is offline
Old 05-18-2021 | 06:10 PM
jeff32's Avatar
on my boat, the fridge was on a small support bottom was thru bolted thru wood. had to find where, cut an X on the bolt head to reach it and had to do another X cut where there was carpet covering a hole just big enough to enter my arm and reach the bolt in the support... some contorsion but that was the trick !
jeff32 is offline
Old 05-18-2021 | 06:15 PM
jeff32's Avatar
If ever picture helps!
i added some cedar support to improve the angle of the fridge to be straight with the wall because it was a little bit off and screws got loose when running in the rough... now its perfect
jeff32 is offline
