Imco question on planing >
Old 05-23-2021 | 03:34 PM
Default Imco question on planing
I just swapped a bravo xr lower to a imco sc lower. Already had a scx upper. Only issue I’m having is getting up on plane. The xr lower jumped on plane no issues. The imco rolls up to 3k no issue then feels like the prop slips and have a heck of a time getting to roll over. Even with dropping tabs. Anyone else experience this?
Pulse74 is offline
Old 05-23-2021 | 03:54 PM
F-2 Speedy's Avatar
are the lowers the same length ? drive shower ?
F-2 Speedy is offline
Old 05-23-2021 | 03:56 PM
everything the same. Standard length on both. I assume standard is the same length. Prop depth is the same at 4.5 at neutral
Pulse74 is offline
Old 05-23-2021 | 03:59 PM
F-2 Speedy's Avatar
did you install a drive shower ?
Old 05-23-2021 | 04:00 PM
no, just the built in shower on the scx
Pulse74 is offline
Old 05-23-2021 | 04:18 PM
F-2 Speedy's Avatar
seems odd, same prop and shaft depth and blows out, Im going from xr's to -1 imco lowers haven't ran the boat yet hope I dont have issues
Old 05-23-2021 | 04:25 PM
yeah so far I’m not sure about the swap. Boat also now leans to starboard on cruising. Tab doesn’t do much for correcting.
Pulse74 is offline
Old 05-23-2021 | 04:28 PM
SB
Cavitation plate same size ?
SB is offline
Old 05-23-2021 | 04:36 PM
yep didn’t do anything to the upper
Pulse74 is offline
Old 05-23-2021 | 04:51 PM
F-2 Speedy's Avatar
can you post a pic of the drive
