Drain procedure 496 MAG >
Old 05-24-2021 | 04:20 PM
Default Drain procedure 496 MAG
I have a 2005 496 MAG HO with black murky water in the closed cooling system and need to flush it. But where do i drain the system? Anyone got some pictures or drawings of the drain plugs?
I got no oil or bad odor in the water, and no water in the engine oil, so i dont suspect there is anything wrong other than old antifreeze.
Kimwiig is offline
Old 05-25-2021 | 05:38 AM
Ayuh,..... The block drains are one on each side, down low, just above the oil pan, port side is just ahead of the oil filter boss, 'n the other just ahead of the starter,....
Bondo is offline
Old 05-25-2021 | 07:44 AM
Block Drains 496 Circled
techman is offline
Old 05-25-2021 | 07:57 AM
Thanks, now at least I know what I’m looking for.
Kimwiig is offline
Old 05-25-2021 | 09:09 AM
And please make sure you use plumber's tape or the goo on them when you reinstall. I've had friends skip that and it made things difficult for them.
Barnacle Bill is offline
Old 05-25-2021 | 09:14 AM
You could have a leaking heat exchanger, so the coolant has been slowly diluting with sea water.
87MirageIntruder is offline
Old 05-25-2021 | 09:58 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
The "pink" coolant is only good for 7 seasons, maximum. After that it starts to turn dark/metallic, and silts up, and doesn't flow/cool as well.
On a twin engine boat, sometimes it is REALLY hard to get to those drain plugs. Do the best you can to get it all out. If you can't get to both of them, you can flush with good clean water to get a majority of it out.
Sydwayz is offline
Old 05-25-2021 | 10:20 AM
I got single engine, but still pretty tight. I think I’ve located one of the bolts so I’ll start there.
Kimwiig is offline
Old 05-25-2021 | 06:45 PM
Yeah, rinse out the expansion tank too. It will be filled with black metallic sediment.
Keith Atlanta is offline
