Kiekhaefer Aeromarine Parts Crate
Hey, I have parts for a Kiekhaefer Aeromarine boat. I do not know much about their history, but I do have some pictures. If someone is seriously interested I could get more detailed pictures. Some of the parts are (2) complete out-drives, (2) complete transmissions, (2 refurbished props), transom brackets/inner and outer, power steering pumps, lift cylinders, stainless up-sweep headers, stainless water cooled exhaust pipes. Any advice would help, thanks for reading -
outdrive
transmission tag
serial number on lower unit
part where lower unit attaches to transom
outdrive
transmission tag
The drives are TRS/SSM II outdrives. Depending n the input shaft they could be for a Merc trans or Borg Warner trans. If the spines are internal, its for a Merc trans. If external, for a Borg Warner trans. Price depends on condition, but generally considered weaker than the TRS outdrive because of the small lower gears. The transom assembly is a TRS also. Looks clean but old from the bubbling paint. Price depends on the amount of play in the gimbel. Thge tag that says Model number 475, which part was that attached to ? PM me your number. Id like to talk to you about the rest of the parts.
