500 EFI High Idle? >
500 EFI High Idle?
500 EFI High Idle?
Old 05-27-2021 | 08:37 AM
Default 500 EFI High Idle?
Just started my motor coming from winter hibernation. Idled normal for a few mins, increase the throttle and wouldn't return to 800 RPM - sits up at 1500. TB is closed, all vacuum lines are connected. Timing confirmed - same goes for all sensors. Temp sensor reading correctly, No codes
Any thoughts?
snowrunner is offline
Old 05-27-2021 | 08:57 AM
SB
If convinced not vacuum leak or tbody blades hung open s tad, could be stuck IAC (idle air control valve.)
SB is offline
Old 05-27-2021 | 06:13 PM
Seems to be the problem, replaced an IAC with a new one last season chasing an issue that turned pout to be the distributor. Swapped the original back and it idles at 800 again!
TY
