1998 Baja 232 Switch Panel switch IDs
Does anyone have a picture or manual or anything on their switch panel? Most of mine are wore off so I'm not sure what they are for.
My main issue is the depth sounder doesn't work and i can get it to work , the gauge powers up and I can set the depth alarm but it never shows a depth so i assume that one of the switches powers the transducer ?
The switch marked 'GPS' originally said 'Depth Finder' and powered the...depth finder, lol. But on mine it powered the whole thing on. I suspect you may have a bad transducer. I wired my GPS chartplotter into the same circuit as my depth finder so it turns them both on at the same time.
Baja 252 Islander
Baja 252 Islander
sounder is 2nd to last on right.
my boat is getting trailer work today but I just redid my switches with labeled units so ill get you full layout. BUT if it has power then your transducer may be loose or unit is bad. switch brings power to unit.
