B1 bent prop shaft >
B1 bent prop shaft
B1 bent prop shaft
Old 06-05-2021 | 06:49 AM
Default B1 bent prop shaft
hey guys,
trying to see my options for a bent prop shaft, i through a dial indicator on it yesterday and its definitely bent.
should a guy buy a lower and swap it out
just replace the shaft
or send it out to get replaced
All_hustle is offline
Old 06-05-2021 | 07:21 AM
obnoxus's Avatar
Charter Member #1171
Just Replace the shaft. You will also need the bearing that is pressed on. There are some special tools and possible reshiming needed depending on your skill set.
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 06-05-2021 | 08:30 AM
timing could play into this...if you can get the repair done (replacing the shaft as obnoxus suggests) quickly...parts available, etc then certainly this is a great and much-less expensive option. On the other hand, if you can find a good used Bravo 1 drive for sale, that is about a 2 hour fix and you're back on the water.
bajaman is online now
Old 06-05-2021 | 09:21 PM
Mine was $700 to replace with OEM
xlint89 is offline
Old 06-06-2021 | 09:13 PM
Buy an SEI lower
https://www.sterndrive.cc/Mercruiser-Sterndrive.html
Griff is offline
