353 Fuel Sending Unit >
Old 06-06-2021 | 08:26 PM
Default 353 Fuel Sending Unit
Hi all. Finally got my new to me 02 353 in the water and its a great boat. Only issue I found this weekend relates to the fuel gauge which shoots to fuel as soon as the key hits the runs position and stays at full for a short period of time, then drops to 1/4 full. I believe ( and confirmed again) that the boat was full of fuel. Sounds like a sending unit, but others may have a different thought based on what I described. After putting about 2-3 hours on it, it does not. show any drop in level at either the full mark or 1/4 full. Boat is an 02 353. Does anyone know specs on a fuel sending unit. Dealer only item or other sources. I know that tank depth is a must know dimension. Thanks for your help.
Racngrn is offline
Old 06-06-2021 | 11:59 PM
Email Scott at Formula with your HIN and he’ll send you the part number you need for sending unit. You’ll find him and anyone at Formula to be amazing when it comes to your new boat!!
Faster Daddy is offline
Old 06-07-2021 | 05:55 AM
I have same boat. Replaced with Centroid and it works great. Less than $100. Call them - they can help.
386-423-3574
Coryfred is offline
Old 06-07-2021 | 07:04 PM
Thanks Guys. Scott provided a WEMA number and contact information for Florida Marine Tanks with part number. He's great. I see that WEMA appears to have been sold to another company, but the 14 inch sender looks to be generally available. I'll order that. Thanks for your help
Racngrn is offline
Old 06-07-2021 | 09:02 PM
You can certainly do want you want. Scott is awesome - he actually helped me today. The Centroid Sender that I installed seems different than the WEMA offerings by my quick review. The sender I installed is auto calibrated to the 353 Tank. I can supply more info if needed.
Coryfred is offline
