Parting 87 10 Meter Fountain >
Old 06-11-2021, 06:44 AM
Full Force's Avatar
Default Parting 87 10 Meter Fountain
Bought 87 10 meter Fountain to part out, hull has some wet and engines mismatch he'd but run perfect..ask for what you need.
I have a perfect running dart block 540 here, has Eagle rotating assembly with flat top pistons, 10.0:1 GM rectangle port heads, roller cam, Edelbrock performer rpm intake and holly carb, engine will be flame arrestor to oil pan, with accessories and wiring with flywheel, no bell housing.
Drop in and go boating!! Approx 600 HP
Low hours but not sure how low, trying to get paperwork from the last owner. oil looks great and runs flawless, I have video of it running but you have to PM me won't let me post it. Exhaust is NOT included! Plan to remove 6-11-21 if possible or early week of 6-15-21 as of now can be ran but not for long.
7000.00 picked up Olmsted falls Ohio 44138
Other engine is,
Mercruiser 450 hp marine engine, freshwater use nice and clean, Gm rectangle heads, edelbrock performer rpm intake, holly carb. Will be sold flame arrestor to oil pan, no exhaust
Runs flawless I have videos won't let me load pm for that.
5000.00 picked up Olmsted falls Ohio 44138
Plan to remove tomorrow 6-11-21 or early week of 6-15-21
Parting out a 87 fountain ask for parts
Full Force is offline
Old 06-11-2021, 06:56 AM
jeff32's Avatar
nice older fountain !!!
jeff32 is offline
Default Drives
Baja 250es is offline
Old 06-11-2021, 08:40 AM
Rookie's Avatar
Received 1,217 Likes on 586 Posts
Originally Posted by baja 250es
Drives ????
trs
Rookie is offline
Old 06-11-2021, 09:29 AM
Full Force's Avatar
Drives are TRS
Old 06-11-2021, 12:38 PM
Default Tabs
What about that tabs complete setup how much for them
Old 06-11-2021, 10:13 PM
Interested in the complete Teak unit door assembly. What's the measurements.
open87 is offline
Old 06-13-2021, 04:15 AM
Full Force's Avatar
1000. With pumps and lines
Old 06-13-2021, 08:12 PM
Default Sea strainer
Sea strainers ?
Old 06-14-2021, 05:06 AM
Full Force's Avatar
Old school style if I tank from hull 200. Pair
