7.4 l injector question >
Old 06-11-2021 | 10:20 AM
Default 7.4 l injector question
1997 ,mercury mpi has large round looks like half metal half plastic body.had injectors tested ,bad spray pattern and most leak.question is are automotive injectors same lbs per hrs? This is 330 hp with peanut port heads.have injectors for 97 gm one ton with 7.4 l and they are physically identical. Had them tested side by side with original injectors at 42 psi and old injector flowed 76 cc and new truck injector flowed 60cc at same rate and time.injector tech thinks old ones are flowing more cause of leaking during pulses .any thoghts?
Ironhorse dave is offline
Old 06-11-2021 | 10:36 AM
F-2 Speedy's Avatar
Id check with Smitty ( articfriends ) on here, he does a lot of injectors, he'll probably see this thread
F-2 Speedy is online now
Old 06-11-2021 | 11:01 AM
Ok thanks ,I'll wait to see if he sees it ,I dont know how to contact him directly
Old 06-11-2021 | 11:45 AM
F-2 Speedy's Avatar
I'll pm you his #
