Engine hatch actuator (acculift)
I am in need of a replacement actuator motor for my engine hatch. It is original acculift actuator motor model MQ347, serial PV24188Q, dated 1995. The hatch motor is weak and no longer has the power to lift the hatch. It has dc power. Just worn out. I’ve tried to find a replacement online with no luck. I’ve also tried to call Danny (supposedly) of acculift in Michigan, with the number I’ve found through this site. And was unsuccessful. No answer or call backs. Anyone that can help with any direction to go or a compatible replacement motor would be great. Thanks.
Do you have the hatch on relays or just off the switch at the dash? If no relays I would suggest putting them in. They move 3 times faster and have the power. My Scarab deteriorated also and relays fixed the issue.
I can take the motor off. I checked voltage with it lifting and had a heavy draw, down to 8.5v. I don’t believe it to be on a relay. But that may help. Anyone have a wiring diagram of a example for one with a relay. I haven’t been able to find a aftermarket replacement motor without having to buy the entire lift assembly for $500.
You can't do it with 1 relay. I use a reversing motor solenoid/relay.
https://www.ebay.com/itm/16490501345...EAAOSwzmRgwLda
I did this because of same slow issue and I made a wiring diagram for installation. just send email to [email protected]
Cole Hersee Forward & Reverse Relay Module 24452-BX | O'Reilly Auto Pa (oreillyauto.com)
