242 LS Prop question >
Old 06-14-2021 | 09:50 AM
Default 242 LS Prop question
I have a 1986 242 Formula. Boat is in excellent condition, trailer queen & freshwater all its life. Last spring I swapped out the oem 260hp Merc for a fresh 300hp mag mpi. (Alpha 1)
I am running a 19p 3 blade stainless prop. (Not sure what brand) anyway, at WOT the tach is around 4,000- 4,100 and running 46mph (GPS) any prop recommendations? Is 4k ok to run at WOT? If its "lugging " will it burn excess fuel? It seems to get out of the hole fine. I have a 21p Mirage plus but I know I probably need to go the other direction. (I haven't tried it as its 4k with the 19p)
Alwhite00 is offline
Old 06-19-2021 | 08:25 AM
There is more power at higher rpms. And you need them.
To get there get a shorter propeller pitch.
Sell the 21. My (smaller) 223LS won't max out a 21 pitch with a 420 horse 383 stroker. But my engine is not a stocker so I can go past 5000 rpm.
I'd say get you a 17" Mirage plus and spin to win. You want to reach 4500 or even more rpm.
NHGuy is offline
Old 06-19-2021 | 09:02 AM
Ballpark figure - 1" pitch is 200 RPM
speicher lane is offline
Old 06-19-2021 | 09:10 AM
What gear ratio on the Alpha?
Baja 252 Islander
bajaman is offline
Old 06-19-2021 | 10:26 AM
Google mercury Marine prop selector.... very straightforward and you are over propped .. best results, as Bajaman was asking requires gear ratio for your drive (1.36 or 1.62)
