Fault 19 over speed >
Fault 19 over speed
Fault 19 over speed
Old 06-25-2021 | 06:20 AM
Default Fault 19 over speed
What can cause this consistently at 3800 on 525. Thanks
Rheeder218 is offline
Old 06-25-2021 | 06:39 AM
you should have a switch on the shift plate, its the in-gear switch. The switch is telling the ECM that its in neutral. Unplug the switch and it will go away. Unplugging it hurts nothing, but your idle might change by 50 rpms
AllDodge is offline
Old 06-25-2021 | 03:21 PM
I’ll give that a try thanks! But on my vessel view it shows that the motor is in gear when put into gear. Put it in neutral it shows in neutral.
Old 06-29-2021 | 05:56 PM
I've read a failing crank sensor will also trigger the overspeed fault.
endeavour32 is offline
Old 07-01-2021 | 12:03 PM
Issue was fixed with replacing the gear selector switch that was suggested to unplug. Thank you!
