Strong enough?
Old 06-30-2021 | 10:03 AM
Default Strong enough?
What do you guys think? This should do the trick right?
HawkX66 is offline
Old 06-30-2021 | 11:46 AM
If that repair link between the boomer and the trailer is not welded together it isn’t safe
liberator221 is offline
Old 06-30-2021 | 11:51 AM
I was thinking about welding that, but I had seen so many other set up and the u-bolts or mounts they were using weren't even close to being as strong. I probably will end up welding it though.
HawkX66 is offline
