7.4 mercruiser twin, one will not rev over 1000
Hoping SOMEONE has seen this. One 1990 7.4 engine I've determined has a short somewhere. Not sure how or why, but one is not affected and the other is. I thought it was fuel related so I emptied the tank, replaced the fuel pickup, the fuel pump fuel line, water separator and fuel filter. Still having issues. Sometimes if both engines are running it's ok, but alone 80 percent there is issues. So while the engine was running I discovered if I shut the battery switch off it ran nice and smooth off the new alternator. Turn the battery switch on won't rev over 1000rpm and just choughs and chokes. Shut battery off again and it runs smooth. Sounds like a short somewhere??? Any ideas???
Now it seems like my damn Thunderbolt 4 module is dead, WTF. I have 12v on the purple wire at the coil but nothing on the white/red coming out of the ignition module. Maybe this F'd up wiring caused issues with that also??
I just bought this 1990 Carver Allegra twin 454's with Bravo 2's last year, drove it home (about 160 miles) with no issue until I got to my port then all this started. Any suggestions with wiring and/or ignition module would be greatly appreciated.
You’ll have to check for proper wiring and power/ground to the ign module
As far as batteries and switches, few ways to skin the cat, but here is 1 of them:
https://www.perko.com/help_guides-wi...attery_switch/
During the winter months I'll rearrange the battery system, it only makes sense to separate things like you pointed out. Summers too short here to keep working on the damn boat, lol.
