gen 6 502 mpi   aluminum water pumps >
Old 07-04-2021 | 09:08 PM
Default gen 6 502 mpi aluminum water pumps
lost a seal in my bone stock--engine mounted water pump today. anyone ever run an aftermarket aluminum water pump. I ran an Edelbrock one on my small block for yrs. In lake michigan, corrosion is not too much of a problem. Is edelbrock still a viable option? and what part number will fit my 502 gen 6 block?
wuzzgunna is offline
Old 07-05-2021 | 07:05 AM
Unless your closed cool using AF, only use a marine water pump
AllDodge is offline
Old 07-05-2021 | 07:57 AM
SABER28's Avatar
ok, but why? you already have aluminum heads ,intake etc.
in fresh water that gets used for a few months and then winterized i dont see corrosion happening
SABER28 is offline
Old 07-05-2021 | 01:22 PM
Aluminum will corroded, just takes longer in fresh water
AllDodge is offline
Old 07-05-2021 | 01:37 PM
The issue is corrosion, if your comfortable with the risk then order one from one of the speed shops. They are physically the same size. A lot of boaters are "same for same " the answer your most likely going to get is to replace it with a genuine Mercruiser part. From a car guys point of view a Mercruiser 502 MPI is just a big block Chevy with a crappy fuel injection strapped on it and in the end it takes BBC parts .
carnutsx2 is offline
Old 07-05-2021 | 07:29 PM
Ya but? BBC parts from what generation. If you look at generic Chevy car parts, are they before 1972, short shaft corvette pumps, standard 72-1991 gen part. There are approximately. 10 different BBC water pumps. Or? With an add on Hardin marine stainless housing, will a stock impeller flow enough through a inlet crossover with bypass to keep my manifold cool enough.?
Old 07-05-2021 | 10:04 PM
But I can't give you first hand experience, in the end I put a cast iron replacement in my 540 build, the weight isn't an issue. But more importantly I dont want to give you incorrect information. Call Summit or Jegs and get one assuming the rotation is correct. I would assume the exhaust flow will be just fine but thats a guess .
Old 07-06-2021 | 08:58 AM
TomZ's Avatar
It’s a short-style pump.
And, I’d go for the marine replacement. The impeller is uni-directional and made of stainless. I’ve run an automotive pump (small block) in fresh water and it last two seasons. Replaced with a marine version and to my knowledge it’s still kicking some ten years later.
TomZ is offline
