Go Back  Offshoreonly.com > Technical > Electronics
Donzi 35ZR Nav Light Question >
Old 07-06-2021 | 03:18 PM
Question Donzi 35ZR Nav Light Question
Hello all
I have recently purchased my dream 35ZR and have what may be a stupid question. My port side navigation light currently does not work. I assume the bulb is bad. I went to change the bulb (or at least attempt to) and got no where. The lights are recessed into the deck which is really cool but I cannot figure out how to access them. My original thought was through the anchor locker but to no avail. They do not appear to be able to simply 'pop off/out'. Does anyone have any knowledge of this?
Thank you in advance.
pr1orities is offline
Old 07-06-2021 | 03:19 PM
Old 07-06-2021 | 03:41 PM
DiamondPerformance's Avatar
Offshoreonly Advertiser
Have to go thru the anchor locker to replace them, I used a LED bulb for a replacement.
www.diamondperformanceparts.com
[email protected]
http://www.facebook.com/pages/Diamon...07878772615803
302-521-0123
The Best Parts & Service At The Best Price
DiamondPerformance is offline
Old 07-06-2021 | 03:51 PM
That was my initial thought - I popped the locker open but cannot find a way to access the lights. Is there a trick or something obvious that I'm missing?
Old 07-07-2021 | 05:07 AM
neva satisfied's Avatar
Its a long reach but you can do it. You will be almost upside down to reach it. If you cut the zip ties holding the wires in place you should be able to pull the light and socket right out through the anchor locker to change it.
neva satisfied is offline
Old 07-07-2021 | 10:36 AM
Always nice to know the tricks. I will take a closer look. Thank you!
Old 07-12-2021 | 11:19 AM
All
thank you for your knowledge.
I was able to get everything squared away. It was relatively simple once I knew what to look for.
Thank you again!
