Sea pump sealant?
Old 07-06-2021 | 09:13 PM
Default Sea pump sealant?
I’ve got a 2 stage sea pump… not sure the brand but has a “KE” logo on rear plate.
do y’all use any kind of sealant on the mating surfaces wearplates and “blocks”?
They have o rings but looks like a small amount of sealant was used on previous assembly in a couple areas, or it’s just some kind of residue.
I usually just lightly grease o ring seals but thought I’d ask before I re-assemble.
Also, any cool looking machined aluminum replacements for these plastic blocks or is it plastic for a reason?
Metalguy38 is offline
Old 07-07-2021 | 12:01 PM
It should not need any sealant if the O rings are good. Sealant may have just been used to keep the O rings in place.
Griff is offline
Old 07-09-2021 | 09:32 PM
Ok, good deal. Thanks griff
Old 07-09-2021 | 10:49 PM
SB
Some people think they have to put rtv on every freaking thing. Lol
SB is offline
Old 08-25-2021 | 09:42 AM
I don’t use sealant and it’s fine just make sure you scrape off whatever was there before so it mates correctly
Nassauk is offline
