38KV - Pulling the tank? >
Old 07-12-2021 | 11:20 AM
Default 38KV - Pulling the tank?
First time long time here...anybody out there in the 38KV Scarab world know how to access and clean a 88' 38KV gas tank without having to pull it??
keukabound is offline
Old 07-18-2021 | 10:59 AM
hblair's Avatar
If you remove the access panel off the cockpit floor you can see the the top of tank. You can then remove the float/gauge sending unit and remove it to see in the tank with a camera on a wand. You’ll only be able to see the rear of the tank because of the baffles. If you gave to remove the tank, it’s going to be foamed in place so removing it is going to be cutting the foam with a sawzall and prying the tank up. Which is not a small chore.
hblair is offline
Old 07-18-2021 | 07:55 PM
Yes...I was afraid of that. I pulled the cover and the inside needs to be completely cleaned. Tank has not been used in over 13 years. Looks like the tank is coming out.
THANKS!!
Old 07-18-2021 | 09:13 PM
Some solvent and a trailer ride to slosh it, drain, and repeat a couple times can really clean it up. Then rig up a fuel polishing setup.
sailtexas186548 is offline
Old 07-19-2021 | 09:20 AM
How would I drain it? Using a siphon pump system?
Old 07-19-2021 | 09:27 AM
hblair's Avatar
My first thought would be some hose connected to one of the fuel pickup straws, and an electric fuel pump pumping thru a hose to a container outside the boat. That'd get most of it out anyway.
hblair is offline
Old 07-19-2021 | 09:37 AM
phughes69's Avatar
Heath is THE EXPERT on all things about redoing a Scarab 30, 300, Pnather, S-Type, 377, 38KV,
phughes69 is offline
Old 07-19-2021 | 09:47 AM
Yes..ok...because that's how I emptied the old gas out of it was with a siphon pump. I've already committed to removing the tank for optimum cleaning results.
Old 07-19-2021 | 10:22 AM
hblair's Avatar
Be sure you know what you're committing to before you do it.
hblair is offline
Old 07-19-2021 | 10:49 AM
Thanks for the heads up!!!
