Sun Sport and ohers probably question (alarm) >
Old 07-16-2021 | 10:50 AM
Default Sun Sport and ohers probably question (alarm)
High water alarm, when triggered, does it also turn on bilge water pump? or its only an alarm...
fotonews is offline
Old 07-16-2021 | 11:20 AM
Mine doesn't have an alarm, try filling bilge from hose until alarm sounds, is the bilge pump going?
GLENAMY 242SS is offline
Old 07-16-2021 | 11:23 AM
F-2 Speedy's Avatar
generally the bilge pumps are wired hot and the when the water level rises it triggers the micro switch to turn on the pump
F-2 Speedy is offline
Old 07-16-2021 | 12:52 PM
There are 2 float switches, one next to pump which turns on when a few inches of water and then 2nd float switch few inches above 1st one which triggers alarm but not pump, is this normal? what is the Coast Guard requirement? My boat needs to do a Coast Guard inspection
fotonews is offline
Old 07-17-2021 | 09:51 AM
Yes this is the correct setup. you don't want the alarm going off every time the bilge pump runs...
SabrToothSqrl is offline
Old 07-17-2021 | 05:59 PM
If you have an auto pump, make sure there is no oil in the bilge. Those coasties will have your nuts for discharging oil in S. Florida.
ph1971 is offline
