Center consoles
Old 07-17-2021 | 12:15 PM
Default Center consoles
I am debating between a 34 Sunsation or a 34 nortech
Rockpile5 is offline
Old 07-17-2021 | 12:18 PM
maybe this can help?
noli is offline
Old 07-17-2021 | 12:29 PM
Discussed heavily here:
34-36FT Performance Center Console Advice
Stuckonstupid is offline
Old 07-17-2021 | 12:37 PM
noli is offline
Old 07-17-2021 | 04:52 PM
Where do you do most of your boating? Will it be used for fishing at all?
36Tango is offline
Old 07-20-2021 | 08:12 PM
Ing's Avatar
Ing
Veteran: Marine Corp
Compare core materials and layup. Make note the Nor Tech gives you details about their construction. Sunsation, not so much.
Ing is offline
Old 07-21-2021 | 12:08 PM
VP of the tickfaw200
after being on both boats its hard to say. go ride on them and see what you think.
caseyh is offline
Old 07-21-2021 | 05:22 PM
21 Hustler's Avatar
curious as to why the 34 nor tech is made offsite and just finished at the factory, vs the rest of the lineup which is all done at the factory. Does someone else build the 34? Is the construction different?
21 Hustler is offline
Old 07-22-2021 | 10:39 AM
Only has to do with space. The 34 is mostly rigged at the old facility, same place all the boats used to be rigged. its the perfect sized shop to rig a 34 but once you got a bunch of 39's and 45's in there it was packed. The old facility still houses the glass shop and paint booth for all models and most of the rigging on the 34. The construction of the 34 and 39 are the same and all done by Nor-Tech.
erik1976 is offline
Old 07-22-2021 | 12:25 PM
I’d go nortech
hogie roll is offline
