Go Back  Offshoreonly.com > Technical > Electronics
4 trashed MSD boxes in 5 hours?? >
Old 07-24-2021 | 08:20 PM
Default 4 trashed MSD boxes in 5 hours??
I need some direction if anyone can help. I just had new motors built and installed (572 NA) in my 96' Top Gun. Everything was brand new from scratch. They installed MSD 3L's and I have burned up 4 of them in 5 hours 2 on each motor. We switched to the 2L's, same deal. I'm tired of throwing parts at it and everyone is stumped. I'm hoping the hive mind can steer me in the right direction.
MJ11 is offline
Old 07-24-2021 | 09:20 PM
Rookie's Avatar
Are they wired straight to the battery? If not, probably your problem. If a decent distance from battery up the gauge of the wire.
And straight to the battery is not the battery cable at the starter that goes to the battery.
Rookie is offline
Old 07-24-2021 | 09:26 PM
Are you using compatible coils?
There's a coil compatibility chart on the Holley site.
zz28zz is offline
Old 07-24-2021 | 09:29 PM
Yes wired to the battery, not sure how far would be considered far. I'm guessing 6-8 feet and not sure on the wire gauge. Will check with mechanic.
MJ11 is offline
Will check, thanks!
MJ11 is offline
Old 07-24-2021 | 09:32 PM
They are MSD blaster coils, couldn't find the chart though.
EDIT: Found chart
MJ11 is offline
Old 07-24-2021 | 09:49 PM
https://www.holley.com/support/ignition/
Look for link "Wiring Diagrams and Tech Notes" (PDF file).
All the "Blaster" coils seem to be compatible with the 6-series boxes.
zz28zz is offline
Old 07-24-2021 | 10:15 PM
Craney's Avatar
That’s got to be a new record.
Craney is offline
Old 07-25-2021 | 09:21 AM
Rookie's Avatar
Check your battery voltage. Too high (bad regulator) or too low can hurt them. Also the battery is the best and biggest filter in your electrical system.
Rookie is offline
Old 07-25-2021 | 03:00 PM
Check the voltage difference between the direct battery feed line to the MSD box and the switched hot lead to the box from your ignition switch (can't remember the max. allowable difference..) I had a problem years ago with my '79 233 Interceptor eating boxes (not quite as often as yours) and installed a relay that supplies direct battery voltage to the box when energized by the ignition switch. Haven't had a box failure since (still carry a spare 'tho.)
Good luck- hope this helps!
rer233 is offline
