WTB Gen 6 454 piston and rod >
Old 07-24-2021 | 09:00 PM
Default WTB Gen 6 454 piston and rod
Title says it all. I'm looking for a good used stock Gen 6 454 piston and rod. 4.25".
Sealed Power H749CP
Thanks.
HawkX66 is offline
Old 07-24-2021 | 10:07 PM
Rookie's Avatar
Thanks.
Do you have a piston part #? Is it still the TRW/Sealed Power 2399? I might have a couple laying around.
Rookie is offline
Old 07-25-2021 | 04:49 AM
Thanks Rookie. I'll have to take a look. I didn't realize they used more than one in a Gen 6. I'm just trying to keep everything balanced.
edit: It's not the 2399. That's Mk4 with a dome. Gen 6 are flat top if you're using Gen 6 heads. I'll see if I can find part numbers.
There's a 1602 at the top of the rod. You can't see it with the piston still on the rod.
The pistons in my 69 that I built the same motor for a few years back has Sealed Power H749CP. Same pistons, but I have .030" over in that.
According to Mercruiser, the numbers for the rod are:
NLA 614-3553 superceded by 8M0030663
These aren't anything special, but I want to make sure they're the same as the other seven. I'd rather not have to buy all eight if I only need one.
HawkX66 is offline
Old 07-25-2021 | 08:55 AM
Rookie's Avatar
I'll see what is laying around the shop.
Rookie is offline
Old 07-26-2021 | 07:31 AM
Thanks. If you come across something that'd be great.
HawkX66 is offline
