Help, any Ideas?
Old 08-02-2021 | 11:12 AM
Default Help, any Ideas?
2000 342 Performance. 2 years ago, rebuilt Starboard 502. It is like new, runs perfect. This spring I rebuilt the port 502, by the same shop that has been around for years and years with a great reputation. Sounds and runs well but will not make the same top end. WOT Starboard RPM 5000, Port RPM 4500+ almost 4600. We have checked everything and are out of ideas.
Help please
Lenny
NevadaSmith is offline
Old 08-02-2021 | 11:35 AM
I would start off checking fuel pressure, timing and take a look to see what the spark plugs look like.
underpsi68 is offline
Old 08-02-2021 | 01:37 PM
List the "everything" that you checked.
Griff is offline
Old 08-02-2021 | 02:34 PM
fuel pressure, timing, new plugs,fuel injectors redone,switched tacs, switched ECMs, checked the prop. Thinking about switching drives. going to change throttle cable.
Old 08-02-2021 | 07:35 PM
Swapping drives will do nothing unless one of them has external damage.
Make sure the throttle cable is adjusted properly. Pull the flame arrestor and make sure the the throttle body flap is going to WOT. Unless the cable is hard to move, changing it will do nothing.
Did you check fuel pressure while running at WOT??
Griff is offline
Old 08-02-2021 | 09:02 PM
Fuel regulator was replaced with an adjustable one. A gearhead friend says it should be 40PSI. it is set at 44psi at idle.
Old 08-02-2021 | 09:03 PM
So the answer to you question is no. Not checked at WOT
Old 08-02-2021 | 09:26 PM
43 psi is the stock setting and it should maintain that at all rpms. It needs to be checked while running the boat in the water under load.
Griff is offline
Old 08-02-2021 | 09:29 PM
I will try to get that done this week. any other ideas?
Old 08-03-2021 | 08:04 AM
Wally's Avatar
Were doomed!
Another avenue to look at is the props....i had one prop from a set that were supposed to be 23p each......problem was that one prop had blades closer to 24.5P and it was loading the motor down too. They must have been worked at some point but you couldn't tell just by looking at them
-Wally
Wally is offline
