Millers Set To Tackle Dam Challenge At Lake Of The Ozarks In New Skater 368 >
Old 08-24-2021 | 07:27 PM
Jason Johnson's Avatar
Correspondent
Correspondent
Default Millers Set To Tackle Dam Challenge At Lake Of The Ozarks In New Skater 368
Tyler and Lindsey Miller are planning to tackle the Dam Challenge on Missouri’s Lake of the Ozarks tomorrow morning in their 36-foot Skater Powerboats catamaran.
https://www.speedonthewater.com/mill...ew-skater-368/
Jason Johnson is offline
Old 08-25-2021 | 06:15 AM
Active Streak: 30 Days
Good luck, water looks a little low this morning, could be tricky up around the 70-75 MM.
Helmwurst is offline
Old 08-25-2021 | 08:02 AM
H20 Toie's Avatar
Bummer looked like they were doing good until the prop shaft broke
H20 Toie is offline
Old 08-25-2021 | 09:32 AM
I was wondering what happened. Hopefully everyone is fine. I see they are now at the dock around Brown Bend. Old record stands a little longer.
waterplay is offline
Old 08-25-2021 | 10:18 AM
WARPARTY36's Avatar
Drive to arrive alive!!!
Looks like they're running again.
WARPARTY36 is offline
Old 08-25-2021 | 05:57 PM
I love it! They break, they figure out a way to get it fixed and then they finish what they set out to do. I am sure there is a bit of disappointment, but what a class act! So many would just be *****in' about the weak prop shaft (or whatever broke).
36Tango is offline
Old 08-26-2021 | 12:58 AM
All of it was awesome! I followed it all morning but it does prove that EVERYTHING can break.
flat rate is offline
Old 08-27-2021 | 08:54 AM
Well these new outboards don't.
That's what I read everywhere anyhow. That and 50 year warranties on them.
cheech is offline
Old 08-27-2021 | 09:52 AM
They WILL break.... different boat 450 ( no bang, no strike... just lost power - engine replacement is sometime in Spring of 2022
speicher lane is offline
Old 08-27-2021 | 11:18 AM
So I am wondering will the warranty restart in the spring with the new replacement? When did it break, sounds like at least 6 month down time.
Wildman_grafix is offline
