525 spare parts
Old 09-03-2021 | 08:35 PM
Default 525 spare parts
525 guys what spare parts make sense to keep on board for a breakdown that can be dealt with on the water. Belt, IAC? I had a crank sensor go out last year that I guess isn't very common but ruined the weekend so I have a spare on board. Looking to do some longer runs but want to be prepared. Thanks for any input.
DaveK26 is offline
Old 09-04-2021 | 12:46 AM
H20 Toie's Avatar
i have always carried a spare belt, impeller and housing, alternator, never used any of them.
H20 Toie is offline
Old 09-06-2021 | 07:23 AM
Thanks for the info. Mine are getting up in hours so just trying to be prepared.
DaveK26 is offline
Old 09-06-2021 | 07:42 AM
If your belt has a lot of hours, replace it and keep old for spare
Duct tape, electrical tape and a few hose clamps, fuses. EPIRB
AllDodge is offline
Old 09-06-2021 | 08:30 AM
F-2 Speedy's Avatar
spare set of headers.......
F-2 Speedy is offline
Old 09-07-2021 | 08:11 AM
Dave M's Avatar
Veteran: Navy
Every spare part and the entire Snap-On tool catalog was not going to help me the times I've broke on the water.
Dave M is offline
Old 09-07-2021 | 08:42 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Cam Sensor, Crank Sensor, Full SWP replacement, Rinda/similar scanner, IAC & gasket, fuel water separator.
Sydwayz is offline
Old 09-08-2021 | 09:07 PM
Ha! Yeah no doubt
DaveK26 is offline
Old 09-08-2021 | 09:14 PM
Thanks for the input these all seem logical to have on a long run to save a trip from being cut short
DaveK26 is offline
Old 09-09-2021 | 09:43 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Add to that list:
-A few of the Blue Water Drain petcocks. They sell them in packs of 5 I think.
-Serpentine Belt
-Plug wire set
-Spark plug set
-Various Hose Clamps
Even if you have sensor or similar failure that you don't have with you; the Rinda scanner is a priceless tool to have. I loaned mine out nearly as much as I used it myself, including on poker runs and the like. If you don't have the sensor or whatever you need on hand, you can at least know if it's a $49 part that you can overnight in and get you back on your way.
Sydwayz is offline
