525 efi stock fuel system capabilities >
Old 09-13-2021 | 02:11 PM
Default 525 efi stock fuel system capabilities
525 efi stock fuel system. How much hp can the stock pumps and injectors support?
troyc565 is offline
Old 09-13-2021 | 03:15 PM
rvtransport's Avatar
700 HP plus on stock injectors. But intake will not allow enough air anything after 600hp even with larger throttle body.
rvtransport is offline
Old 09-14-2021 | 09:00 AM
Thanks. I am replacing the intake with a better flowing setup.
troyc565 is offline
Old 09-15-2021 | 01:21 PM
articfriends's Avatar
What Intake? Keep in mind, a 525 uses honda/keihan style injectors ( 22 MM grommet seal on bottom/ 11.5/12mm upper feed) so there are very few intakes that would use those injectors beside early 454/502 mags, 525s and hondas, Smitty
articfriends is offline
Old 09-16-2021 | 08:35 AM
nothing a bridgeport can't fix and some blank fuel rails
sutphen 30 is offline
Old 09-16-2021 | 08:59 AM
So they aren’t one off unicorn piss molded into a custom injector made on the USA for one and only one guy that repairs 120 ecms a day yet has enough time to be on here all day?
just a Honda based injector. That’s cool
Unlimited jd is offline
Old 09-16-2021 | 09:07 AM
SB
Lol.
I’m glad some see the light.
chuckle
SB is offline
Old 09-16-2021 | 09:08 AM
F-2 Speedy's Avatar
that right there is funny chit.............. plus custom PCM tuning for several race teams......
F-2 Speedy is offline
Old 09-16-2021 | 11:54 AM
I probably wouldnt go thru all that just to reuse the factory 48 lb Keihans, LOL
Old 09-16-2021 | 02:05 PM
your right,,I like to squeeze in some 80 pounders.
