Carburetor tuning book ?
I have to rebuild a holley 4160 4 barrel w/ vacuum secondaries, list #80551
Is there a book on tuning/fine adjustments to help it work better all around.
there is a comprehensive assembly instructions manual from holley on the web, and i have good help from 2 guys, but i'd like to dig a little deeper and maybe learn something.
the kit is here, just waiting on floats, any special tools tips tricks suggestions would be great.
Thanks cdshack, I did that but just got confused and would rather have someone suggest "so and so's carb voodoo book" is what your after.
the carbuetors' that thing on top of the engine that makes a giant suckin sound right ?
The first thing I'd do is turn it into a 4150 by removing the secondary metering plate and replace it with a metering block so you can actually change jetting and have 4 corner idle adjustment.
Good 1st book to get ….basics on rebuilding and tuning. I got my copy 30+ yrs ago. Lol.
[img]blob:https://www.offshoreonly.com/cce2e10d-fae7-4975-8310-d6885849efe9[/img]
The first thing to do is ditch the secondary metering plate and put a metering block in. Otherwise there really is no tuning the secondary side of the carb. After that you'll need to test with different jets front and rear to get it to make the most power.
thanks everbody, books ordered !
griff, 2 more adjustment screws would get me 4x's deeper in trouble, "just" smart enough to know i shouldn't be messing around with this, but too cheap to buy new 700 bucks.
