Dart Pro 1 vs AFR - Preferences? >
Old 10-18-2021 | 03:26 PM
Default Dart Pro 1 vs AFR - Preferences?
Grabbing parts for a 540 build. Dart tall deck blocks, SCAT crank, Eagle rods, SRP pistons, Dart single plane intake. 10.03:1 compression. Considering Dart Pro 1 310 cc heads or AFR 300 oval port heads. Experience and advice? and....go!
SnoNinja is offline
Old 10-18-2021 | 04:30 PM
SB
Make sure to do the dart block lifter oiling mod so last few lifters get decent oil. Some reason doesn’t get talked about much. Do google search and you’ll find it wuickly.
As far as heads, both are decent. If buying assembled get your builder or machinist to check clearances and installed pressures.
SB is offline
Old 10-18-2021 | 04:52 PM
F-2 Speedy's Avatar
I ran AFR 305's on my 540"s EFI...........these were Smith Power builds, probably comes down to preference and cost, as SB states have them checked
F-2 Speedy is offline
Old 10-19-2021 | 09:22 PM
I have oval ports... let me know if you need any help or info.. Al AK Racing 905-252-0592
adk61 is offline
