Weight of a 24 >
Weight of a 24
Weight of a 24
Old 11-26-2021 | 03:23 PM
Default Weight of a 24
Does anyone know the weight of a 24 sb with a big block and a bravo? Considering a new trailer and I’ve done some research but keep coming up with different numbers thanks in advance
nhrafreak92 is offline
Old 12-06-2021 | 12:04 PM
superboat1989's Avatar
Superboat web site hull at 2,000 lbs ,Superboat 24 Foot Step Bottom Offshore Powerboat
8.2L with Bravo drive1400 lbs https://www.marinepartsexpress.com/P..._2L_MAG_HO.pdf add fuel
60 gallons fuel @6 lbs/gal 360 lbs
add gear(Battery, tabs anchor ect) 300 lbs approx. weight
Gets you to around 4,060 lbs
If in doubt call John at Superboat 631-226-1761
superboat1989 is offline
