540 + blower engines >
Old 01-03-2022 | 08:11 PM
Default 540 + blower engines
Looking for (2) 540 + cu in blower engines or 8-71 or 10-71 blowers
Cig38topgun is offline
Old 01-16-2022 | 06:41 PM
cariveau's Avatar
Default have some
I have 2 nice 582s with 10-71 and best of everything built on Dart Big M blocks. Also have enough parts ready on the shelf to build a 3rd short block to match. They dyno at 1100 HP and are out of the boat now. Thinking of selling boat without power so then these motors could be available.
cariveau is offline
Old 01-16-2022 | 06:54 PM
What price do you want for them ?
Old 01-23-2022 | 09:59 AM
Hi, I have a pair of 600+ci, 1000+ hp fresh Zul builds. only dyno time. $40k for the pair. Engines are complete, sitting in my heated garage. Unfortunately boating is no longer on my radar which is why these were never re installed in the boat. Best of the best!!
benjen is offline
Old 01-23-2022 | 07:04 PM
Default More info
do you have some more specs and some pics ?
you can text me if you like 443 309 9359
thank you
Old 01-24-2022 | 08:18 AM
cariveau's Avatar
You can see the boat and power at this classified link on Offshoreonly. $25k for the pair of motors without exhaust and transmissions.
https://www.offshoreonly.com/classif...er-o81004.html
cariveau is offline
Old 01-25-2022 | 06:41 PM
thank you
I do have pictures and one of the engines running on the dyno. However, believe it or not I dropped my phone this morning shattering the glass and now the key pad doesn't work. As soon as I can get it up and running i will text you. The specs are: Dart tall deck blocks, Callies cranks, Oliver rods, JE pistons, Bullet cams, Isky EZ Roll, lifters, Manton push rods, AFR 377 heads, TD shaft mounted rockers, Jessel belts, BDS intake, CP coolers, Mooneyham 1471 blowers, dual Holley 1050's, 2 stage sea water pumps, and CP bellhousing coolers (I believe the starboard side has 15 plates the port 13 plates).
benjen is offline
Old 01-25-2022 | 08:22 PM
ive seen and heard these engines run before last freshening. Awesome pieces of hardware and I think 1000hp is very conservative.
Unlimited jd is offline
