ISO Blackhawk Gearcase and/or Complete Drive >
Old 01-08-2022 | 01:47 PM
Default ISO Blackhawk Gearcase and/or Complete Drive
Interested in purchasing a Blackhawk gearcase, Blackhawk unique parts or entire drive. Unserviceable, repairable prefered, but will consider all.
Respond via PM and tell me whatyou have. Thank you!
rotorr22 is offline
Old 01-08-2022 | 02:19 PM
listed by "offshoredrillin" in Maryland
Custom Built Blackhawk, ITS box, 2 sets props 31p
speicher lane is offline
Old 01-08-2022 | 02:37 PM
Saw that one. Thanks. The 1.36 gear ratio will not work in my application. Nice setup, however.
rotorr22 is offline
Old 01-08-2022 | 04:56 PM
offshoredrillin's Avatar
easy to switch it to a diff gear ratio, ITS box is sold with shaft, so only thing left is drive and a set of 31 props, 6k for drive, 1200 for prop, 7k for both.... the xz gear upgrade is good for higher hp
offshoredrillin is offline
Old 01-08-2022 | 05:41 PM
Mbam's Avatar
Offshoreonly Advertiser
I have 8 brand new gearcases and enough parts to build 2 drives.
Mbam is offline
Old 01-08-2022 | 08:50 PM
Thanks offshoredrillin. I'm a retired Mercury application engineer ( old fart), so gear changes are not the issue. I'm running a modest LS3 SBC and require a numerically higher GR based on the engine's HP and torque curve, otherwise I would have been interested in yours. It looked awesome!
rotorr22 is offline
Old 01-09-2022 | 06:38 AM
sure thing, interesting, what ratio are you trying to get to? above 1.5 i think the highest is 1.65 ?... i did mine at 1.36 behind 725 hp as i didnt want idle speed of 10 mph .
Old 01-09-2022 | 12:09 PM
A 1.65 would work for me, though one of our engineers did a 1.81 combo behind a stock 502 mag mpi motor with success.
Point taken regarding the idle speed. I 've driven my fair share of B3 powered boats and experienced similar on the lighter hulls. Can only imagine that it get's worse when the gearcase drag is reduced.
rotorr22 is offline
Old 01-26-2022 | 07:46 PM
I dont mean to steal the thread but its hard to find anyone with data on these drives anymore. What kind of slip numbers have you all seen on a BlackHawk drive when you at 40+mph?
River Rat 164 is offline
Old 01-26-2022 | 10:18 PM
I don't think I've ever driven 40 MPH.
Two Mercruiser engineers I know who worked with them extensively back in the 90's were Steve Schoderer and Steve Donahue. Both are retired, but you might give FB a shot..
rotorr22 is offline
