Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
How to get white gelcoat back to white >
Old 02-01-2022 | 10:20 AM
Default How to get white gelcoat back to white
I`m working on a project I picked up and I`m wondering if it`s possible to get the white gelcoat to either lighten up a few shades or more or get it back to ultra pure white.
There`s thousands of shades of "white" and this boat`s current white is more like a light mocha or Swiss Coffee and I`d like to get it back to or as close as possible to ultra pure white.
I have a rotary with a Lake Country white wool pad, a Lake Country yellow wool (for polishing), a LC Orange curved waffle (for light polishing). On product I have Presta Super Cut Compound, Regular Cut Compound, and Polish (plus a ```` load of car products, DA, pads, and products if needed). Current plan is Presta compound, Presta polish, colonite 446 super double coat as a sealer.
So far I used the rotary with the white wool pad and the Presta regular cut down one side. It got most of the oxydization off but it didn`t really remove most of the marks in the gel coat or really clean it up and make it white-white. It`s shiney but not super white, I haven`t polished it but I`m holding off until I see if there`s something I can do to make the white whiter or possibally the red more fire truck red vs maroonish-red?
The rear upper pa
Is it possible to lighten the gel a few shades with wet sanding it, or using a different product, or possibally wiping it down with a solvent (mineral spirits, aceatone, etc prior to buffing to whiten it up or handle the burn marks?
Here`s some pics
Mohavvalley is offline
Old 02-01-2022 | 10:55 AM
Heres how the side turned out.
In these you can see the difference between the original swiss coffee and
the fresh pure white and some of the original white that was covered up from the sun.
The hatch cover white edge VS. the swiss coffee gelcoat
Also have some burn marks from the cover being in the sun
Old 02-01-2022 | 07:14 PM
Have you tried another pass with the compound in small area to verify you’ve removed all oxidation?
Powerquest230 is offline
Old 02-02-2022 | 10:55 AM
Drake22.250's Avatar
Wet Sand and buff. LOTS of elbow grease. Brought a 85 Mako back to new doing this.
Drake22.250 is offline
Old 02-02-2022 | 11:49 AM
I would try wet sanding one of the darker areas. Start with 1000 , 1200, 1500, then 2000 grit. Then buff with Total boat buffing compound and a 1750 rpm buffer with a wool pad. Follow that up with a polishing compound and a soft wool polishing pad. If that does not bring it back it has either faded lighter than original or may have been refinished.
1Zoom is offline
Old 02-02-2022 | 12:39 PM
madbouyz's Avatar
Although I don't think you'd want to try this , especially on the deck , I'm gonna throw it out there for future reference .
A few years back a friend with a substantial sailboat asked me to help him out with some cosmetic refreshing .
The boat was moored full time in a rather dirty harbor. I wasn't familiar with this boat up close and thought the hull sides looked fine but the owner had me acid wash the sides , something I'd never done before . (White hull)
I can't remember what it was that we used , muriatic acid/on off , etc but I couldn't believe the difference afterwards .
I thought the hull looked white before we started but the end result was very noticeable.
madbouyz is offline
Old 02-02-2022 | 05:37 PM
Active Streak: 30 Days
On/Off works great, BUT, do not get it on any painted or coated surfaces. It will take hot dipped galvanizing a couple layers down.
Helmwurst is offline
Old 02-02-2022 | 11:54 PM
Acids should not damage any painted or powdercoated surfaces. The sides of my boat are painted and acid gets on the paint whenever I clean the bottom with acid. Same with drives, swim platform and transom assemblies. Bare metal or galvanizing is another story and the acid will etch into it.
As far as the OP's post, you may get it a little whiter by wet sanding and buffing, but it will never be as white as the original. It is from UV rays
Griff is online now
Old 02-03-2022 | 05:48 AM
I made the comment about paint, because I had spilled some on an older lift. It did etch the galvanizing and I was not sure some of the other metal parts were painted or galvanized. Thank's for the clarification Griff, I have used it on trim tabs with no issues
Old 02-07-2022 | 04:23 PM
Wet sand and buff
Vette06 is offline
