Trailer brake fluid cap stuck
Old 02-20-2022 | 02:57 PM
Default Trailer brake fluid cap stuck
So before I give it two ugga's and dugga and break it off... Anyone had an issue where their plastic brake reservoir cap was "frozen" on? Debating on heating it up since it's just plastic/rubber. It's on dico model 10 surge break setup.
Same cap/setup pictured here:
CharlieWhiskey85 is offline
Old 02-20-2022 | 03:31 PM
Think I would heat reservoir rather than plastic cap. Hold tension on cap with socket and tap on reservoir with a hammer, maybe the shock will let it brake loose.
liberator221 is offline
Old 02-22-2022 | 03:07 PM
I had the same issue when I checked mine after purchasing the boat years ago, I ended up having to hit the outer edge with a screw driver an hammer. I'd just go ahead and buy a new cap from etrailer or similar. It will most likely break. The newer caps have bigger hex to grab by hand.
https://www.etrailer.com/Accessories...SABEgIhiPD_BwE
Donzi1979 is offline
Old 02-22-2022 | 04:46 PM
If it's a HEX I would use a socket to distribute the force which worked on mine.
PA.WOODCHUCK is offline
Old 02-22-2022 | 05:10 PM
F-2 Speedy's Avatar
the O-ring is probably rusted to the housing because moisture got in or its empty
F-2 Speedy is offline
Old 02-22-2022 | 06:30 PM
Try using a strap filter wrench.
Easy1 is offline
Old 02-22-2022 | 07:41 PM
Pretty sure it's empty due to how it was pulling.
Old 02-22-2022 | 07:42 PM
Was it a 1" socket? Biggest I had is 7/8. Guessing it's a 1"
Old 02-22-2022 | 09:32 PM
Sydwayz's Avatar
Forum Regulator
Your best bet is a six sided box end wrench of the correct size. Likely a cheap one from Harbor Freight will do it.
Sydwayz is offline
Old 02-23-2022 | 01:43 AM
The OEM cap is either 1 1/6" or 1 1/8"
Replacement caps are even bigger, but only about $10 https://www.easternmarine.com/titan-...er-cap-4830608
Griff is offline
