Go Back  Offshoreonly.com > Owners Forum > Sunsation
Boat Lift Bunks 288 >
Boat Lift Bunks 288
Boat Lift Bunks 288
Old 02-20-2022 | 07:16 PM
Default Boat Lift Bunks 288
I have a 2005 288 MCOB I am setting up a new boat lift. Do I need to make the bunks with a raised portion for the step in the back or can I use a flat bunk?
Lil Mick is offline
Old 02-21-2022 | 10:45 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
You definitely want the bunks cut to fit the exact shape/step of the hull. You can use small strips of wood tacked on top of the main bunks to adjust the height. You also want the main bunks of the lift to support the boat directly under the main stringers.
Sydwayz is offline
