Header bolts /Correct anti seize
I just pulled my stainless Bassett tri-y's off of a new motor wirh aluminum heads, motor has 30 hours on it and the headers have been on for 12 hours. I used nickle anti sieze on the steel cap head bolts that go into the steel adapter plates as well as the steel bolts going into the aluminum heads. The anti seize was much more dissolved and burned away than I had hoped it would be and one counters bolt holding the adapter on required welding a nut on to get out.
Is anyone aware of a better anti sieze for dissimilar metals and the high heat of a header? I read the anti seize thread and some others, but C5-A is the best option I've found, I think, so far. Has anyone been using it, something else.?
Permatex 81343 - Permatex Anti-Seize Lubricant
* Temperature range: -60 to 1,600 degrees Fahrenheit* Salt, corrosion, and moisture-resistant
* Ideal for marine use
* Use on any stainless steel nuts, bolts, clamps or other hardware to prevent thread seizure.
I use black socket head cap screws, grade 8 lock washers and Permatex #80078. Never an issue.
https://www.permatex.com/products/lu...ubricant-8-oz/
Permatex’s Anti-Seize Lubricant is a highly refined blend of aluminum, copper, and graphite lubricants. Use during assembly to prevent galling, corrosion, and seizing due to weathering or chemicals. Anti-Seize assures easier disassembly. Temperature range: -60°F to 1600°F (-51°C to 871°C). Salt, corrosion, and moisture resistant and is ideal for marine use. Non-aerosol version meets Mil Spec #907E. Aerosol – Level 3*
In bold above, was that supposed to be ‘counter sunk bolt’ ?
I’ve never had an issue removing exhaust bolts but never used anti seize on them. With only 12 hours they should back out easily. What size allen on those countersunk bolts? I could see if smaller than 5/16 getting hogged out.
The anti seize should work fine in that heat range according to their claims anyway.
