Stainless air filter material ?
https://www.ebay.com/itm/144476206842?_trkparms=ispr%3D1&hash=item21a373f6f a:g
uoAAOSwfuRiPXVu:sc:ShippingMethodStandard!705 08!US!-1&amdata=enc%3AAQAGAAAA8AWyrY4ubYcj%2FqhTKUCzSHB2M JhFxKSiWG3g6OgdiJmPpw4KXVyzkp%2FyU%2FzYdVfaDX66LHg 4s%2FuwIKpFYnYyE7ZvgJ1qwMaju5m%2BPT%2F%2B%2BlfpjmQ 0Bc5iBULYrk%2BYx8MjSMgl%2BiOcssD9NSaPOA21Tcjkau1N7 uhU4l79f3Adi%2B283CVaeJsBtV0lxDy9Ciu2VxN8k%2BIMljZ cDaL3lEkboA2jjKBS7%2FhzpY55cjap3wRPbceH6QLqXaLxErU 2kW9dka6WonvT4LLTpiTbIYPye7t2eYirT1hccvN6PXyQ1xyxY EG%2F%2FhlgTVDTB5E2ESUfRQ%3D%3D%7Ctkp%3ABFBM5J3eyf lf
Starting point. You need to measure circumference . You will need to have the pieces cut / tig weld . You may want to post in "wanted" section . Some have removed layers and just go with 1 which is not performing as a flame arrestor at that point.
uoAAOSwfuRiPXVu:sc:ShippingMethodStandard!705 08!US!-1&amdata=enc%3AAQAGAAAA8AWyrY4ubYcj%2FqhTKUCzSHB2M JhFxKSiWG3g6OgdiJmPpw4KXVyzkp%2FyU%2FzYdVfaDX66LHg 4s%2FuwIKpFYnYyE7ZvgJ1qwMaju5m%2BPT%2F%2B%2BlfpjmQ 0Bc5iBULYrk%2BYx8MjSMgl%2BiOcssD9NSaPOA21Tcjkau1N7 uhU4l79f3Adi%2B283CVaeJsBtV0lxDy9Ciu2VxN8k%2BIMljZ cDaL3lEkboA2jjKBS7%2FhzpY55cjap3wRPbceH6QLqXaLxErU 2kW9dka6WonvT4LLTpiTbIYPye7t2eYirT1hccvN6PXyQ1xyxY EG%2F%2FhlgTVDTB5E2ESUfRQ%3D%3D%7Ctkp%3ABFBM5J3eyf lfStarting point. You need to measure circumference . You will need to have the pieces cut / tig weld . You may want to post in "wanted" section . Some have removed layers and just go with 1 which is not performing as a flame arrestor at that point.
