400R vs 450R
Old 03-30-2022 | 08:24 PM
Default 400R vs 450R
It seems like the 400R on the used market is a tougher sell than the 450R. I understand that everybody wants the latest and greatest and extra power/speed, but what other differences are there? Am I correct that the 400 requires premium while the 450 does not? Is the 400 just a detuned 450 giving it a longer life span? Do they use the same lowers or is the 450 more robust? The top end speeds do not seem allot different (5-10%?) but it sounds like the 450 accelerates harder? Does one or the other have mechanical or electrical issues that the other may not have? Thanks in advance!
36Tango is offline
Old 03-30-2022 | 08:36 PM
Apples and Oranges. The 450 is a supercharged 4.6L V-8 that turns 6400 rpm. The 400R is a supercharged 2.6L inline 6 cyl. that turns 7150 rpm. 450 pulls harder, 89 octane fuel, faster on top end, way more torque for loads and planing. 400R has been a great motor overall and works well with multiple engine setups. The motors are close in weight, the 450 comes with a 1.60 gear and the 400R comes with a 1.75.
Joe
JPEROG is offline
Old 03-30-2022 | 08:49 PM
450R is nearly double the price.
hogie roll is offline
Old 03-31-2022 | 06:08 AM
Originally Posted by JPEROG
Apples and Oranges. The 450 is a supercharged 4.6L V-8 that turns 6400 rpm. The 400R is a 2.6L supercharged inline 6 cyl. that turns 7150 rpm. 450 pulls harder, 87 octane fuel, faster on top end, way more torque for loads and planing. 400R has been a great motor overall and works well with multiple engine setups. The motors are close in weight, the 450 comes with a 1.60 gear and the 400R comes with a 1.75.
Joe
400r is also supercharged.
IGetWet is offline
Old 03-31-2022 | 08:09 AM
And they both break propshafts constantly, that Mercury always has a shortage of. I waited over 2 months for a propshaft back in 2019 and a friend of mine has been waiting over 3 months now for one that he broke recently. Two years later and the story is still the same - even the new style propshafts break, and you can't get replacements when they do break. Just plan to buy a spare set of lowers and you'll be fine - that's what one of my friends has done. Me personally, I traded off my 400R boat for a 700/6 drive boat and haven't had any issues since. But, time will tell.........
Skater30 is offline
Old 03-31-2022 | 10:04 AM
Correct I didn't intend to mislead. I have 3 450s, and two 300Rs. Total of 800 hours run time roughly and have never broken a shaft. Thru hub propellers don't buzz the boat nearly as bad as an over hub, I also run Porta transom brackets on everything I own and lower the motors in rough conditions and when coming on plane. I think its lack of common sense in many cases of "not all" when prop shafts have broken.
ex: when you accelerate hard with your truck while pulling a load and it torque shutters; do you just stay in it and hope the drive line lives? In a drag car when you launch and get tire shutter; do you stay in it and hope for the best? NO, you let off and make another attempt. I have witnessed several drivers buzz their entire boat for 5 seconds or more in attempt to get on plane with high X dimensions and big 5 blade propellers on the motors (something is going to break).
Dale is correct that there is a supply defect with vendors supplying Mercury with prop shafts. I do have extra cases (in case).
Joe
JPEROG is offline
Old 03-31-2022 | 10:08 AM
And continuing to go up.
LET'S GO BRANDON.....
Joe
JPEROG is offline
Old 03-31-2022 | 10:24 AM
LOL, no kidding there was a picture Pete had posted from I think from key west. It was a 4 engine CC that was flying, props all the way out of the water, when you zoomed in the guy still had the throttles pinned to the dash.
I am sure doing that regularly will turn out well.
Joe
Wildman_grafix is offline
Old 03-31-2022 | 11:20 AM
Drake22.250's Avatar
I have triple 400r on my center and was thinking about going to 450r. A very good source (sells lots of mercury outboards) told me to stick to my 400r for there reliability for what that is worth. Only issue I have had is when I had steering actuator issues, stick to gen 2. My engines are 2015.
Drake22.250 is offline
Old 03-31-2022 | 02:48 PM
What are hearing about 450s?
