2007 Mercury Verado 250 FSM casing over pressurized and burst!! >
Old 04-03-2022 | 10:01 PM
Default 2007 Mercury Verado 250 FSM casing over pressurized and burst!!
Good day all,
I have a 2007 Mercury Verado 250 Fuel Supply Module that potentially had a bad lift pump. I changed all parts in the FSM to avoid having to take it all apart again and when I installed it I filled the bowl and connected all hoses, it primed up fine and so I turned over the motor and the FSM casing burst. I thought maybe the casing was potentially suspect, I had another FSM I was going to rebuild, which was lucky so I built that one up and installed it and again the casing Burst. What could cause that! Obviously something is creating too much pressure but I would think there is a relief somewhere in the system but I cannot find info. Any help would be appreciated. Thank you
(I have done this before with no issues on my other motor)
JMcCarthy is offline
Old 04-04-2022 | 02:33 AM
It does have a pressure regulator, is it possible you swapped position of pumps put the high where the low should be? I always replace the whole module if it is available liability reasons.
tony357 is offline
Old 04-04-2022 | 08:14 AM
Hey Tony thanks for the reply. There is only one way they can be installed into the top of case.
Old 04-04-2022 | 09:59 AM
I am wondering if the float is working opposite which is keeping the lift pump on therefore over pressurizing the system. Anyone have thoughts on that?
