Bravo transom fixture needed
Hello All.
I would like to borrow a transom cutout fixture if possible. If anyone has one or knows of one that would be helpful. I would buy a new one if something was to happen toit. Thanks Jeff
Ayuh,..... The Bravo, 'n Alpha Gen.II are the same,.....
I use an ole piece of transom cut outa an ole boat to mark the bolt holes, 'n key hole, then a drill jig to keep the drill motor plumb to the transom to drill out the bolt holes, 'n a jig saw to cut out the key hole,.....
After that, I use a die grinder with an aggressive bit to open the key hole for clearance,....
