M1 oil filter question
Mercury-Mercruiser 35-881126K01 High Performance Oil Filter
so says:
https://www.mercruiserparts.com/bam/...1361/15970/180
threads are the difference M1-302 is correct filter, however it does not have a bypass. The M1-303 is same as 302 with a bypass valve, does original filter have a bypass valve? Is it better to have the valve than not.
According to the microfiche drawing/parts look up i linked from BAM above, there is a high 30psi bypass (#3 on look up) on the filter head. Therefore, i’d say a non bypass filter would be better. What does the factory filter have ?
Btw: The Napa 1060 (wix51060) are popular on the 525 EFI /700SCI and etc. No relief. Yes on antidrainback. Some like the racing versions: Napa 1060R / Wix 51060R
51060 specs:
https://m.wixfilters.com/Search/PartDetail?PartID=230356%20&Source=WESR
51060R:
https://m.wixfilters.com/Search/Part...20&Source=WESR
51060 specs:
51060R:
Here is the OE Filter for the 565
so says:
so says:
