buying an old cig >
buying an old cig
buying an old cig
Old 04-24-2022 | 09:54 PM
Default buying an old cig
I searched the forum and couldnt find much info on buying an older cigarette, more likely than not I will be looking at a cafe racer so late 80s early 90s boat.
Is there a list or resources to help me in going through the boat and potentially a list of things to avoid or seek out?
Thanks in advance!
BigTom77 is offline
Old 04-25-2022 | 08:37 AM
cig28's Avatar
Normal stuff to look for is wet transom, stringer and fuel tank leaking. I’d look for a bravo drive boat . TRS boats are out there and are going for an affordability price but they stopped making them in 1993 and parts are becoming very scarce. Also speedmaster boats are out there but #3 speedmaster drives with small shafts are limited on prop selection and parts are becoming hard to come by also. When you get into the speedmaster drive boats your limited on who can repair them.
cig28 is offline
Old 04-25-2022 | 10:03 AM
F-2 Speedy's Avatar
BT 77, did you see the 91 Carbon 70 edition in the classifieds ? if its in your budget, EFI engines B Max drives 300 hrs on the hull......
F-2 Speedy is offline
Old 04-25-2022 | 07:38 PM
how hard would it be in the future to upgrade from TRS drives to a bravo or equivalent?
Thats a sweet boat but is currently a bit out of my price range currently. Maybe they would take my vette in a trade lol.
BigTom77 is offline
Old 04-25-2022 | 07:46 PM
I provided a comprehensive write-up in this thread
87 Cigarette Cafe 35
1MOSES1 is offline
Old 04-25-2022 | 08:45 PM
seafordguy's Avatar
massive job. New transom, motors moved, exhaust reconfigured, etc. never would it be worth it….
seafordguy is offline
Old 04-26-2022 | 12:42 AM
Thats exactly what I"m looking for, thank you!
I'm reading that the konrad 540 is a solid unit thats plug and play for if/when I kaboom a TRS assuming they are still made that seems like a viable option.
BigTom77 is offline
Old 04-26-2022 | 07:11 AM
cigrocket's Avatar
Honestly, Unless you put 650HP+ to the TRS Drives and abuse them, they will last a long time. I have also seen spare TRS's Cheap for backups. If I were buying a Cafe or Older Gun my order of drive selection would be SSM5, SSM3A, SSM3, TRS, BRAVO. The boats were designed to have transmission drives which helps the CG of the boat.
10-71 transmission is stronger then the merctrans. Also the 10-71 can be built to 925 Huber Specs.
PS I did the KONRAD conversion on my Mistress Years ago when they first came out. They were as advertised, but I got a pretty good deal at the time. I think You would save quite a bit by just tracking down some spare TRS's in the offseason. Lower Pinion Gear Fails when the case flexes. I believe the RH drive fails most if memory serves me because of the pinion gear placement.
Just my 2 cents
cigrocket is offline
Old 04-26-2022 | 09:13 PM
Gotcha, thankyou for the info!
BigTom77 is offline
Old 04-27-2022 | 05:57 AM
Just my 2 cents
pretty sure the velvet drive number is 1018 for the green tag 72c trans.
Unlimited jd is offline
