38 Cig v berth
Old 05-04-2022 | 10:23 AM
bigboat28's Avatar
Default 38 Cig v berth
I want to get rid of the canvas support in cabin. I have 1/4 inch ply cut to fit. Am I able to fiberglass both sides and make it strong enough for 2 to sleep on? If so, how many layers and what material do I need to use? Want to keep it light.
bigboat28 is offline
Old 05-04-2022 | 10:57 AM
F-2 Speedy's Avatar
Id beef it up to 1/2 or 5/8 inch and build a center support off the two stringers and screw it into place that way you still have access to underneath
F-2 Speedy is offline
Old 05-04-2022 | 11:04 AM
bigboat28's Avatar
Was planning on cutting an opening over where ac unit goes and attaching piano hing for access there.
Trying to figure out if and how to make the 1/4 inch strong enough without a bunch of supports.
Old 05-04-2022 | 10:28 PM
J-Bonz's Avatar
Pack when we had our gun made pops placed 1/4” wood right over the top of that sail loft thing that supported the original cushion. It worked out well.
J-Bonz is offline
Old 05-05-2022 | 09:32 AM
If you want light, I would run some aluminum angle crosswise to support it. I think 3 pieces should be sufficient. If you bolt it to the side supports you can always remove it for access.
ThisIsLivin is offline
Old 05-05-2022 | 07:23 PM
a "T" section of aluminum glued , screwed and glassed on to the panel.
carnutsx2 is offline
