SSMIII Parts, cases, shafts, gears, bell housing >
Old 05-23-2022 | 08:16 AM
wieland77's Avatar
Default SSMIII Parts, cases, shafts, gears, bell housing
I have 2 sets of SSMIII parts, enough to complete 1 drive and then some. I believe the only thing I'm missing for both drives to be rebuilt completely is one prop shaft. All cases and shafts are in very good condition. Also have a good SSM bell housing with new pin bushings and input shafts. Will sell all together or tell me what you need and we can go from there. Cell: 989-415-0290
wieland77 is offline
Old 05-24-2022 | 07:25 AM
resurrected's Avatar
What ratio are the uppers?
resurrected is offline
Old 05-24-2022 | 07:43 AM
wieland77's Avatar
Its been to long for me to remember for sure but I believe they were 1.48:1
Old 05-24-2022 | 09:05 AM
Thank you for the prompt response
That doesn't jive with upper ratios I have in my manual.
Do you remember what you final ratio was?
What were they behind for engines?
If that is a "Z" on the upper case (I can't quite make it out), with the "W" on the lower, it would be 1.33 and 1.125 for a final of 1.5
How much are you looking for the parts?
Old 05-24-2022 | 12:10 PM
wieland77's Avatar
I do remember that the final drive ratio was 1.5:1. The lower stamp is W 3172 RH which is partially assembled, only the prop shaft has been removed. The other lower is stamped W 3391 LH. RH partially assembled upper is stamped C577243 Z, and the other upper is stamped C850444 Z. I had them behind a 12 meter fountain with 540's about 650hp. Give me a call if your interested in some pieces or would consider taking everything.
Old 05-27-2022 | 07:49 AM
wieland77's Avatar
Sold
