Best Scan tool for DIY Guys. 2007 496 Mag >
Old 05-31-2022 | 11:09 AM
Default Best Scan tool for DIY Guys. 2007 496 Mag
Just bought a 23' Baja 07 Outlaw with Merc 496 Mag i/o. 292 hours. I generally do whatever DIY I can on my cars and have the SCAN tools needed to pull codes, fix it and then clear them.
What do you guys recommend I get for my motor? I see Techmate Pro and Rinda Diacom seem popular. Thanks for your suggestions and any links you can offer. Thank you.
Nucc100 is offline
Old 05-31-2022 | 11:13 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Rinda
https://www.rinda.com/rindashop/shop/techmate-pro/techmate-pro-94706
I wouldn't own a modern engine having a scanner handy. You also need the dongle for that engine.
Sydwayz is offline
Old 05-31-2022 | 02:43 PM
I have the Techmate, and is real handy. If you get into some heavy problems you would like the Diacom software and a laptop so you can use the record feature and see more thinks then 4 at once
AllDodge is offline
Old 06-01-2022 | 12:21 AM
The Rinda Techmate is the only handheld scanner that will work.
Last I saw, they were out of stock everywhere
Griff is offline
Old 06-01-2022 | 11:23 AM
Originally Posted by Sydwayz
Rinda
Sydwayz,
I still have the one you bought for me at the bar in Miami Boat Poker Run.....Can't remember the year but it was Three Nor-Techs and Two Cigarettes ago!! LOL ( Guessing around 2014 ??)
I don't use it anymore NUCC100 if you would like to buy it... I "think" I spent $350 or $400 on it.
Came in really handy when I had my 525 boats!!
Thanks, Patrick
Spicy is offline
Old 06-01-2022 | 01:16 PM
Looks like they are back in stock https://www.michiganmotorz.com/techm...cm-555-ecm-555
Griff is offline
Old 06-01-2022 | 01:21 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Originally Posted by Spicy
Sydwayz,
Thanks, Patrick
You were brave taking boating advice from me while were both in a bar drinking! I'm glad it paid off.
Sydwayz is offline
Old 06-01-2022 | 09:23 PM
If you have twin engine’s I would highly suggest spending the extra coin and buying the Diacom so you can record and compare both engine’s. Regardless if you plan on working on any of these engines you will need one or the other.
1BIGJIM is offline
Old 06-07-2022 | 01:10 PM
Thanks guys. I got the Techmate Pro from Michigan the other day. Fast service. 499.00.
Nucc100 is offline
